Mangum
08-23-2012, 01:44 AM
Are there an output wire anywhere to hook up a Tach in a 2000 SS??? Looking to put an adjustable shift light in as the tach cant keep up..
Thanks
1LOMARO
08-23-2012, 07:47 PM
The #10 white wire on the PCM under the passenger side of the dash should take care of what your looking to do.
Nemesis350
08-23-2012, 08:00 PM
You can also get a tach signal from the main coil pack plug which seems like what people tend to use for nitrous setups (i guess), but i also prefer the white #10 from the pcm.
Although i'm curious if you can tap into the tach signal from under the dash?
WhiteBird00
08-24-2012, 07:13 AM
Clarification... the wire is the white wire in position #10 of the red connector in the PCM which is mounted to the firewall under the hood on the passenger side.
