Lots of stuff, ls1, ws6, transmission, rearend, suspension, performance
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NV
Item Condition: Used
Engine: Small Block
LS Engine?: Fits LS Engine
Prices do not include shipping or paypal unless otherwise noted.
Stock Ws6 parts (black / ebony)
Exterior:
- Black OEM WS6 Hood - $1000
- Honeycomb tailights (59k miles)- $285 shipped (set of 2) / 150 shipped each
- Ttops - $75 each, $100 set
- Doors (complete black or pewter) - $125 each
- Gas door (1 white, 1 black, 1 pewter) - $25
- Side mirror (black, pewter)- $45
- Front bumper support (w/ ws6 foam) - $100
- Window washer reservour - $20
- Rear bumper shock absorber - $30
- Rubber Rear spring toppers - $20
- WS6 rear springs - $50
- Stock LCA's, Pan hards, sway bars - PM me
- Bump stops (2 sets) - $20
- Fog lights w/ housings - $40
- Drivers side headlight assembly black - $250 shipped (EBAY: http://www.ebay.com/itm/271067996669...84.m1558.l2649 )
- Headlight Assembly, needs paint (1 Driver, 1 Pass) - $200 shipped each
- Headlight assembly cover only; Brand New OEM, unpainted - $50
Under the hood:
- Lower Ram Air box (with ram air lid or LS1 Motorsports lid) - $150 shipped
- Stock airlid w/ baffle- $30
- Stock Ramair airlid w/ baffle - $40
- Ls1 Intake - $100 shipped
- K member towers (set) - $50 (prob have bolts too)
- Upper A arms (set) - $40
- Brake Booster - $30
- Brake Master Cyl - $40
- Ls1 brake calipers (front and rear set) - $100
- Under hood fuse covers (excellent condition, set) - $20
- Plastic bellhousing starter cover w/ bolt - $15 shipped
- Auto trans exhaust mount - $20
- Traction Control module w/ lines- $100
- Cruise Control modular w/ bracket - $100
- AC parts (lines, condensor, can, heaterbox & compressor) - PM me
- Stock MAF $50
- Heater hoses - $50
- Upper radiator hose - $10
- Steering linkage - $50
Interior:
- TA Carpet Dash cover (ebony) - $30
- Carpet - $100
- Center console (grey) - $90 shipped
- Interior Fuse Panel cover - $15
- Console parts
- Pass airbag dash cover - $50
- A pillar - $10
- Ttop holders - $35
- Window buttons w/ bezel - pass $25, dvr $35
- Auto shifter parts - PM me
- 2002 Firebird Owners Manual w/ Pontiac sleeve - $20
- 2001 Firebird Owners Manual w/ Pontiac sleeve - $20
- Ws6 Speaker set (all 8, 59k miles) - $50
- Maunal Pedal Assembly (w/ sensors) - $70
- Auto Pedal Assembly (w/ sensors)- $40
- Glove box - $40
- Rearview mirror - $15
- Headlight switchs - $20
- Seatbelt guides (black) - $40 shipped
- Seatbelt guides (tan) - $30 shipped
- Hatch Struts - $30
Transmissions:
- Auto crossmember - $30
- T56 crossmember - $60
Clutches / Converters:
- Stock TC - $40
Motor Parts:
- ls1/ls6 Rockers set w/ trays - $50
- ls1/ls6 Pushrod set - $50
- Ls1/Ls6 front timing cover (w gasket)- $40
- Ls1/Ls6 rear cover (w gasket)- $40
- Stock used Ls6 Oil pump - $20
- Center Bolt Valve cover set - $100
- AC bracket & tensioner - $50
- Alt Bracket - $40
Harnesses:
- Ls1 T56 Engine Harness - $400
- 99+ ECU - $100
- 98 Ls1 Auto Engine Harness - $250
- Ive got a bad auto harness if you need connectors
--- Injector connectors (sets of 8, i have 2 sets) - $60 shipped
- Ls1 Auto or manual body harness - $150
- Ls1 Trans am engine bay harness - $100 w/ fuses
- 4 channel Rearend harness - $30
- Ws6 rear taillight harness w/ bulbs - $50
- Fuel Pump harness - $40
Bolt sets:
- Rear Torque arm to Diff bolts w/ nuts (set of 2) - $10
- Trans to torque arm mount bolts w/ nuts (set of 2) - $10
- K member bolts (set of 6) - $15
- Master Cyl U bolt w/ nuts - $10
- Motor mount bolts (set of 2) - $10
- Motor mount tower bolts (set of 4, per side) - $10
- Pan hard bolts w/ nuts (set of 2) - $10
- LCA bolts w/ nuts (set of 2, per side) - $10
- Stock Torque converter bolts (set of 3) - $10
------ Performance: ------------------------------------------------
Air Intake:
- Black LS1/LS6 GM Performance carb style intake (88958675 cathedral port) - $375 shipped
- Ls1 motorsports Lid (Similar to slp lid) - $75
Suspension:
- (4) QA1’s SA - 275 front spring/Ws6 rear - $800
- Summit Racing rear shocks - $50 set
- Hotchkis Strut Tower Brace - $200
Rearends:
SOLD LIST:
- Ls1 T56 no bellhousing - unknown condition - SOLD
- 12 bolt - SOLD
- Taillight harness - SOLD
- 10 bolt 3.23 rearend - SOLD
- TA Door (dvr, Black) - SOLD
- TA skirt (dvr, Black) - SOLD
- TA Fender (dvr, Black) - SOLD
- BMR SFCs, bolt on - SOLD
- BMR Extreme torque arm and crossmember with DS loop - SOLD
- SLP Lid 98-99 - SOLD
- SLP Lid 01-02 - SOLD
- Pass airbag - SOLD
- Motor mounts, clam shells (set) - SOLD
- Heater Hoses - SOLD
- Dash pad - SOLD
- Headliner - SOLD
- White OEM WS6 Hood - SOLD
