What injectors are you running?
Old 08-23-2012, 12:00 PM
konceptracin's Avatar
Default What injectors are you running?
Please list injector you are using along with size, engine size, turbo size and hp levels...
Thanks
Old 08-23-2012, 12:06 PM
Lockdown99ss's Avatar
SVO 30# red tops - 364ci, N/A, 400rwhp
Old 08-23-2012, 12:11 PM
Also are they tuner friendly?
Old 08-23-2012, 12:17 PM
Moderator
denmah's Avatar
80lb Siemens Deka ev6 high impedance from lethal performance
pencil style spray pattern
50psi base fuel pressure 22lbs of boost from a GT45 turbo
650+rwhp
stock 5.3l 4l80e trans
they will idle great on a stock 4.8l and only use about 50% duty cycle at 530-550rwhp with an unlocked automatic
must have installed 10 sets of these by now, only 399 shipped i think they are the best deal and most flexible, great results on stock ecu, megasquirt, AEM and DFI.
Old 08-23-2012, 12:50 PM
650+rwhp
Great review... I think I would need something bigger tho I have a 408 with a gt5588 Also will be on a aem and e85
Old 08-23-2012, 01:45 PM
00ultraz28's Avatar
I just picked up a set of FIC 1000s 95lbers .... cars not running yet but from what I've read they work well.
Old 08-23-2012, 02:07 PM
Yes let me know abou these!
Old 08-23-2012, 05:01 PM
Anyone run mototron?
Old 08-23-2012, 05:12 PM
98transbum's Avatar
FIC 1000 ran perfect tuned by Henderson performance. New build is getting FIC 2000
Old 08-23-2012, 05:28 PM
What fuel and were you maxing out the 1000?
Old 08-23-2012, 05:37 PM
I8UR4RD's Avatar
Not running yet, but:
FIC 2000 (192lbs @ 43psi)
390 LQ9
F1-A Procharger
900-1000rwhp
4l80e
Going to run E-85.
Old 08-23-2012, 08:18 PM
silver_82's Avatar
Billet 120s on e85 @43 base pressure and roughly 800rwhp puts me at 85% duty cycle
5.3 with twin 66s
They are pretty large low imp injectors but idle good. I turned the base up to 55psi and it seems to idle better. Maybe the spray pattern gets better??? Have yet to go romp on it yet with the higher base but im expecting for the DC to go down to about 75%
Old 08-23-2012, 08:42 PM
5.3 with twin 66s
Moran... Correct? Not sure why more people don't use them.
Old 08-24-2012, 07:06 AM
Them fic look really good I'm going to call them today
Old 08-24-2012, 07:58 AM
dschmittie1's Avatar
I am running the FIC 127# high z injector. Making 800+rwhp on E85 and still plenty of room to grow with the injectors
Old 08-24-2012, 09:18 AM
pwrtrip75's Avatar
160lbs Billet Atomizers. High z. They work well once you get them tuned right... With no available injector data they are a pain to tune.
370ci, E85, PT76GTS. Idle fuel pressure is about 47psi. 20lbs of boost and 1:1 = 67psi fuel pressure im at 59% duty cycle on the injectors.
Old 08-24-2012, 09:33 AM
Restricted User
98Z28CobraKiller's Avatar
BonnarLS1 and I both use the Holley Billet 120 low Z injectors. They are good to about 1000-1050 rwhp on E85. They are cheap, have good data and idle clean and lean. I love'em.
Stay away from the cheap low imp Bcsch/Ford 160's. Every car that I've tried tuning with them has been nothing but problems in the drivability.
Old 08-24-2012, 09:41 AM
ZL1Killa's Avatar
FIC 732s (69.65#) tuned and running great
Old 08-24-2012, 10:04 AM
98transbum's Avatar
switching to e85 shooting for 1200 on the new 427. just collecting parts right now. lme is getting the shortblock order. I need a pair of fenders since we hit the wall, if anyone has some pm me. preferably silver
Old 08-26-2012, 08:33 AM
Talked to fic and got a good deal on the 127's,I'll let you guys know how the work!
Quick Reply: What injectors are you running?
