Come in, throw me some input. LQ9 swap.
Old 08-23-2012, 03:22 PM
1MeanTA's Avatar
Lightbulb Come in, throw me some input. LQ9 swap.
Alright guys, I about have all my parts rounded up for my LQ9 swap into my 99 trans am. Wanted to get a little insight into anything else I may need, also curious if anyone knows anyone with a similar setup to guage where I will sit HP wise.
1999 Trans am, M6-
I had previously made a thread concerning a major smoking issue i came across after a simple header replacement and it turned out to be the worst case scenario. I had noticed excessive oil consumption at about 91,000 miles, along with SOME oil buildup on my #7 spark plug when they were changed and I added a 100hp wet shot ..plate kit (those plugs had over 40k on them).
It always had great oil pressure, ran mobil 1, and never seemed to miss a beat, I replaced my rear end gears and put longtubes on it at 94k and from my initial drive after install I had major blue smoke going on once the car was at operating temp..after a couple days I had gotten a catch can, checked my PCV system, and finally checked plugs, found #7 pretty covered in oil did a compression test and determined I have a broken/burnt ring on #7. compression was 150 across the board with 60-90 lbs on #7 (after oiling the cylinder).
I can only assume I had not noticed the smoking issue do to having cats on it previously...
I just got an LQ9 out of a 05 Vortec MAXX with 79K on it...
-Gonna run/swap/add:
-comp cam .80 over pushrods
-Comp gold valvesprings
-Futral F14 camshaft - 232/234 .598/.598 112LSA
-ls6 intake
-stock rockers with trunion bearing kit.
-ls6 pcv system
-catch can
-hooker LT/s with a 3" ORY pipe
-SLP loudmouth
-swap oil pan/waterpump
-C5r timing chain
-melling high volume oil pump
-stock trans
-diamond stage II clutch w/remote bleeder (just received with GREAT service from Jason @ texas drivetrain)
-SLP lid
-fresh diff rebuild with 3.73's..otherwise stock other than a T/A diff cover
-chromoly driveshaft
and pretty much leave the rest untouched engine-wise.
I would assume I will need injectors fairly quickly, suggestions?
I would greatly appreciate any input/suggestions, along with anything I may be missing to get this thing ready to run, especially someone who has done a similar swap. As it sits im doing this budget build at right about 2500-3000 dollars, looking to have a streetable, 420-450hp car.
thanks in advance
cheers
Old 08-23-2012, 06:38 PM
KCS
Moderator
KCS's Avatar
You're going to need to drill and tap a hole on the drivers side of the block for the alternator bracket, and with an engine out of an '05 vehicle, I'm not so sure it will swap in without extension harnesses for the cam and knock sensors.
Old 09-21-2012, 07:03 PM
bww3588's Avatar
And possibly a converter box for the reluctor wheel.
Old 09-21-2012, 09:01 PM
outkast6991's Avatar
My 05 lq9 cam stock with a 24x wheel
Old 09-21-2012, 09:02 PM
And gen 3 placement of cam/crank sensors
Quick Reply: Come in, throw me some input. LQ9 swap.
