99 trans am H/C/I
99 trans am H/C/I
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $9500
Mileage: 124
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
stock short block, with arp rod bolts. livernois stage 2 heads, 243 casting number, patriot dual gold extreme valve springs
new valve seats/seals, titanium retainers
comp hardened pushrods
LS2 timing chain, ls1 ported oil pump
LS6 intake ported throttle body
volant cold air system
thunder racing "trak" cam 640/590L 234/231D 111lsa
LPP longtubes/LPP y pipe
magnaflow rear mount catback.
built T56 from sixspeedinc..stage 4 package
LS7 clutch kit
LS2 flywheel
hurst short throw shifter
4.10 gears/moser axels
alluminum drive shaft
drilled and slotted rotors
edelbrock adjustable torque arm
UMI subframe connectors
KYB shocks/struts
eibach pro kit
the car doesnt have those wheels on it anymore, it will have either 17" firehawk wheels or z06 replicas. it also doesnt have the trans am or hurst badges on it either. they come with the car, but the previous owner took them off for some reason... drivers seat has a few tears in it. headliner isnt perfect but not bad. the edges are starting to peel off in a couple spots. t tops DONT leak. power windows and locks. keyless entry. passenger window is slow up and down. rear hatch button inside of car doesnt work, i think the latch needs to be replaced. ac was removed before i got the car. i'll check around to see if i have an ac kit laying around. i took it out of my turbo car so i should have one that can go with the car. heat works. never driven in winter, only driven in the rain when i'm caught in it.
interested in trade for a c5, subaru wrx or a stock ls1 6spd and cash. 616-510-0793. or pm me.
