Western Members - South Cali mechanic???
View Full Version : South Cali mechanic???
Rerodz
08-23-2012, 10:13 PM
Looking for a mechanic in the Irvine area. My GTO has been overheating.
Thanks ahead of time.
KILLER-LS1
08-24-2012, 02:01 AM
Send me a text tomorrow. I can get it fixed for you. I'm in Tustin.
714-396-6427 ~ Josh
Ryne @ CMS
08-24-2012, 09:31 AM
714-396-6427 ~ Josh
hit up josh.... his camaro doesnt overheat on the dyno, and its got a huge ass turbo in front of the motor lol!!
FU_I_AM_UltraZ
08-25-2012, 11:48 PM
Try swapping your t-stat and rad cap out with new ones. If you're car has a sh*t ton of miles, new water pump if you got the cash to do so and you'll sleep better at night :D
Teamscss.com
08-26-2012, 01:27 AM
Should you need a GTO specialist I am here for you!
858-578-7277
Miramar, San Diego
mannyman84
08-27-2012, 01:08 AM
Might as well replace the fans, head gaskets(just invade they are broken), heater core(just in case it's broken), and radiator (just in case it's plugged).
On a serious note, just get it diagnosed and have someone that knows what they are doing check it properly. Just putting parts you don't need will make you spend unnecessary cash and probably make the problem worse.
Rerodz
08-28-2012, 01:46 AM
So figured I'd swap the tstat before towing it to the mechanics.. Hasn't overheated since ...
Now onto the rearend .. It's been chattering.. I put new fluid in it still chatters
