LS6 cam advancing for lower compression/boost???
Im in the process of going FI on my C5Z and im going to stick with the LS6 cam and 317 heads. Ive already got the double roller adjustable gear set, what do you guys think about advancing it 2* to have a bit more low end to combat the lowered compression with these heads. Do you think itll still rev solid to the stock limiter, or will i be cutting it to short?
this was just a random idea i had...i thought the was the blower will be spinning hard 52,XXX @ 6,700, so i thought maybe the blower would keeping it going strong up top... or would the advance kill it?
thanks guys...
thanks guys...
-A&A V2 Si kit 3.4 pulley (pretty much maxing the blower out)
-ALKY progressive meth kit
-LS6 manifold
-1 3/4" LT's, no cats, Ti catback
-317 head (stock) comp 918's, stock rockers w/ trunion upgrade
-TFS 7.400's
-LS6 manifold
-TFS 7.400's
