how traction control works
Old 04-06-2004, 08:30 AM
WS6FirebirdTA00's Avatar
Default how traction control works
does anyone know where i can find a write up on how traction control works? not only on our cars but on like GM's and Ford's? its for a presentation in my motorsports class
Moderator
jimmyblue's Avatar
Have not found a whole lot on it, just bits here & there.
Here is what happens on the F-body:
1) wheelspin detected on acceleration
2) spark retard - wheelspin stop? If no...
3) throttle relax - wheelspin stop? If no...
4) ABS apply - wheelspin stop? If no...
5) Give up, set ASR OFF light.
Now, a -smart- traction control for a Torsen car
that was about performance, not safety for yer
grandma, would forget about (2) and (3) and just
apply ABS to the spinning rear wheel until -rear-
tire speeds were within some %. But these cars
want to keep the rear from spinning relative to
the fronts (which means you're hosed if you run
bigs-n-littles too).
But I bet your report would get a better grade if
you didn't just write "TCS licks *****, the end"
so don't use me as your only reference. Here are
some relevant "eye candy" illustrations you can
sprinkle on, anyway.
Attached Thumbnails how traction control works-schematic_abs_sensors.gif   how traction control works-schematic_asm.gif   how traction control works-schematic_indicators.gif   how traction control works-schematic_tcs_switch.gif   how traction control works-accelerator-servo-module.gif
Old 04-06-2004, 09:07 AM
Brains's Avatar
Those schematics help a lot, thanks for posting...
Old 04-06-2004, 10:12 AM
deezel's Avatar
thanks for the info, jimmyblue
Old 04-06-2004, 08:36 PM
thanks
