Routing Brake lines with Tubular K-Member
I hope the installer installed mine correctly - UMI K member with upper and lower a-arms.
http://www.flickr.com/photos/1835930...7623345499537/
Well, the stock lines are molded. I tried to follow the natural routing as much as possible. There was a tab on each side for a bracket, so I found a screw that would work and used those two tabs plus zip ties (I think) to secure them along the k member.
