Carbureted LSX forum - Total timing
4drnova
08-25-2012, 10:07 PM
How much total timing should I run?
66 nova
427 ci ls3, l92 cnc heads, scog n dickey ss1 cam, 1 3/4 lts
1050 cfm pro systems 4150 style carb
350 turbo
3.73 gear
10.57@128 best so far street car
Seems like it may have more in it. Any suggestions would be greatly appreciated. Thanks
ZONES89RS
08-25-2012, 10:31 PM
How much you running now? How much compression? A smaller carb may actually gain. 33* is a good base line I think.
4drnova
08-25-2012, 10:42 PM
30 degrees total. Pro systems specked the carb to my set up.
Prorac1
08-25-2012, 11:29 PM
What are the specs on that cam? Eric L
4drnova
08-26-2012, 08:02 AM
236/248 @ .50
.601/.615 on a 112
ZONES89RS
08-26-2012, 08:16 AM
That is a pretty small cam for that engine. I would say it is running where it should be. But you can step up to 32*. Keep movin it up at the track till you lose MPH. Then step back. 408 ci engines I have helped put together were running 248 intake and 254 exhaust. They pulled to 7k but made max power at 6600. Just to give you a idea.
4drnova
08-26-2012, 02:59 PM
any cam sugestions?
windmill
08-26-2012, 04:25 PM
i know mine just a stock motor im running 35 deg total....
speedtigger
08-26-2012, 05:57 PM
66 nova
350 turbo
3.73 gear
That is a great looking combo. Each combo is unique. I would say trial and error is the only way to know for sure.
Prorac1
08-27-2012, 01:43 AM
What does the converter stall at, and what size is the tire? Plus, what does the current combo 60 ft at? Eric L
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
