plastic discs on LS1 injectors
Old 08-26-2012, 08:38 AM
86SS86LS's Avatar
Default plastic discs on LS1 injectors
I have a set of LS1 injectors I plan on using in a 5.3 swap. The plastic discs at the injector tips on 2 of the injectors are partially missing. Should I run them as is?.....replace the discs?......or should i just look for a used set of injectors?
Old 08-26-2012, 09:54 AM
RezinTexas's Avatar
post a picture, that will help
Old 08-26-2012, 10:39 AM
outkast6991's Avatar
If its just the pintle cover FIC said they weren't needed
Old 08-27-2012, 08:27 PM
86SS86LS's Avatar
I don't have a picture of my injectors, I'm refering to the orange disc at the end of the injector in the link below. One of the injectors is missing roughly 25% of the diameter of the injector. Another has a 1 mm notch out of the disc. And 2 of them have cracks.
http://www.highperformancepontiac.co.../photo_14.html
Old 08-28-2012, 05:29 PM
86SS86LS's Avatar
Can these discs be replaced? Are the discs a common size?....maybe something I could find on a FWD GM car in the salvage yard.
Old 08-28-2012, 07:13 PM
FIC sells them but they aren't necessary. Call FIC, nice people
Old 08-28-2012, 08:10 PM
S10xGN's Avatar
PM Chuck Leeper (Old Geezer), he rebuilds injectors for a great price.
Old 11-16-2012, 10:40 AM
Neenjah's Avatar
Did they work?
I have one leaking and the plastic disc is cracked enough I can separate it with my fingernail and get it completely off the injector
Quick Reply: plastic discs on LS1 injectors
