Fuel Pressure regulator
Just ordered my new fuel pump and was wanting to install a new FPR. Its for my 99 t/a and was wondering if anyone had the part number so i can get it orderd. Any helkp would be great. Thanks
Well if you want to know about signals of bad fuel pressure regulator it is lack of fuel pressure, maximum fuel pressure, rich engine running condition and black smoke. To make sure these does not affect your car you should take precautions before hand.
Delphi FP10021 is correct.
I just replaced mine in a 1999 Z28. The best price I found was $55.25 w/ free shipping from amazon.com. So, if you paid $47.79 you did good.
After I had already purchased mine, Lonnies Performance posted that he had them for $39. I would have gone with a board sponsor if I had known.
Setup: 2002 Z28 Convertible w/76mm Rearmount Turbo
Aeromotive 340 Fuel Pump
Racetronix Hotwire Kit
60lb injectors
Otherwise stock fuel system
Running out of fuel at 9psi. AFR climbs to 13
Thanks!
https://ls1tech.com/forums/fueling-i...selection.html
Read this post #3 vacuum referenced with a pressure gauge.
Thanks in advance.
