Prc .650 dual valve spring life?
Not really sure on the recommended life on my prc dual valve springs. Running a tsp v3 cam and coming up on the 20,000 mile mark since the install. I've heard many things when it comes to the life of these springs. I've heard 20,000 miles change them. I've heard 40,000 miles change them........ Any ideas?
FWIW- The PRC .675 EHT double springs that came with my new PRC heads lasted 7,000 miles before they started breaking used with the torquer V3 cam. An outside source told me per the time I purchased my PRC heads and v3 cam (March 2011) that I probably received a "bad" set of springs due to manufacturing. When I told a rep. at Texas Speed this he didn't exactly disagree either. He had told me since I bought my heads in March of 2011, the PRC .675 EHT double springs have been "revised" and offered me a new set of these revised springs for a very nice discounted price. Excellent on Texas Speed's part
Yah I understand that there is no recommended mileage change due to the fact that everyone drives different and has a different cam setup. Mine is a daily driver with the ocational weekend race. I too think I have the old style springs probably so I guess maybe I do need to change them out. I don't feel like checking them every other week just to make sure they're ok haha. Anyother dual spring manufacturers out there with some proven longevity behind them?
I think your style of your lobes will play into spring life... i.e LSL vs LSK. There is no real set lifespan. take a few springs out, closely examine them, test PSI @ installed height and open psi. If your not sure then take a few to your machinist and have him check them out
LS1Tech Premium Sponsor
Darkman is correct, no fixed mileage on springs. Lifespan will just depend on what camshaft you are running, and many other variables. Springs dont know mileage, however they do know heat cycles, how many times they have been compressed, and what kind of abuse they have been through. Using common sense and good judgement should give you a good idea when to check, only the driver and spring knows what kind of abuse it has been through. When in doubt, it doesnt take much to pull some and have them checked out.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
You guys already answered. When it was said to check springs it means to remove them, physically inspect them and then pressure test them. If they are still within tolerances, then reinstall, if not, change all set.
There is no actual "spring is good for xxxxx miles"
There is no rash of broken springs. Of course if you spend all day on the forums you hear every horror story of a broken spring....what would the forums be like if every time a set of spring ran flawlessly for 15-25K miles the owner made a thread? Install the springs and enjoy your car!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
My PRC .650 duals lasted 50k miles before I pulled them. Had them pressure tested/checked by a machine shop and they were still within spec. My guess is that I probably could have went another 50k miles on them. The cam I was using was a MS3 .608lift for 3 years and currently a custom cam for the past 4years with a .598lift.
LOL, glad I could contribute to your good night of sleep, I think!
__________________
