4l60 limp mode??
Old 08-28-2012, 02:16 AM
02_ramair_ta's Avatar
Default 4l60 limp mode??
To start my car is running off a PCM from a 6 speed car. If that effects anything? I did a write entire using hptuners, and all the tables are good, I'm not getting trans codes, or anything.. But the trans is stuck in limp mode, all the wires check out, harness is clean and has good connection.. I'm just not sure if the manual PCM needs something else??
Thanks in advance!
Old 08-28-2012, 02:31 AM
MontecarloDrag's Avatar
You need an operating system for an automatic car. A manual tune will never work even if you copy the tables from an auto tune.
Find an auto tune in the repository and write-entire. It will cost you 2 credits
Use only a stock tune from same year-model car than yours.
Old 08-28-2012, 09:58 AM
Ok, I'll try that, and post the results. Thanks!
Old 08-28-2012, 11:06 PM
Fixed it!! Thanks, now to set my shift points..
Quick Reply: 4l60 limp mode??
