SD vs MAF
I run SD as well. I have no issues besides warmup. It starts looking for a MAF and runs like crap the 1st 5-10 seconds of startup than finds idle.
Other than that I am more than happy with it.
SD is fantastic. It's all in the ability of the tuner to get it correct. With a maf you either have a huge restriction, or buy a $$$ maf. With SD you can have 4" all the way. Only restrictions in my intake setup is the IAT sensor, and a n2o nozzle
0 PSI of boost would be roughly 1 bar. 14 PSI, 2 bar. 28 psi, 3 bar.
At least that's the way I understand it. I'm not sure if there's a 2.5bar OS but you're probably better off starting with the 3 bar.
If you have a 98 ECM like me, you're stuck with the 2 bar OS (at least through HP).
A bar of pressure is roughly 14 PSI (atmosphere at sea level).
