97 trams am new lt4
97 trams am new lt4
hey everybody ,new to the community and need some info. Just installed a 383 stroker with lt4 cam ,eldebrock lt4 intake ,58 mm throttle body ,along with other hi-po mods.Have serious concerns about the stock wiring harness and where to send my ecu to be programmed.Any suggestions on where to get a replacement harness, seems GM discontinued it and everywhere i have called says their harnesses are made to swap a lt1 into another vehicle! Thanks
Yeah you're going to get picked apart on your cam decision and intake....
But anyway, why do you need a new harness???
Send your PCM to PCMforless for a tune or get it dyno tuned.
I'm going to go ahead and say right now that that cam is way to small for a 383. You're leaving a lot on the table. Please tell me you had the heads ported at least??
Its got 97 T/A LT4 on the post LoL Why do you need / want a new harness??? If theres broke connectors get new pigtails & the heatshrink with solder to repair the ends!!! A 383 really likes a cam in the .23x @ .05 intake range A hot cam leaves a lot to be desired with a 383 BUT I will say atleast its all a starting point
Im a stickler on quality parts But I do realize Not everyone can afford a Callies Dragonslayer crank , Howards billet rods & custom JE nitrous pistons for their first build!!!! Maybe hes got a Scat cast assy but He was atleast smart enough to keep the cam at a level where **** wont break!!!! Give the guy a break & Help with the problem!!! For Once!!
Just to clarify the Edelbrock LT4 intake probably has a bad missmatch when mated to LT1 heads but the LT4 intake ports themselves match LT1 ports very well because interanlly it is the same as the later LT1 intakes, just material above the port gets in the way of bolting it up.
The OP is pretty typical though, did an engine build THEN asked questions. Judging from the lack of a second most by him I am guessing he doesn't like what has been said. Judging by when he was last active he probably already saw up through post 9.
