should i start to worrie
hey all first let me say sorry for my ignorance. Ok i rolled my 1998 z28 camaro out of the garage today and i seen coolant on the floor maybe 2-3 drops. Two days ago i hammerd into it alittle and started to smell antifreeze pulled into the gas station popped the hood and looked under the car no leaks what so ever. Now the antifreeze on my floor is green inside the radiator its bright orange. What gives? should i flush the radiator or should i leave it alone? Here are 2 pics of whts in the radiator.
Looks like Dex Cool to me. I just flushed my radiator last week and it looks exactly the same. So your radiator fluid has always been green and then turned this color out of no where? That's odd, are you sure you didn't just top off the radiator with the green stuff one day assuming the radiator fluid was the green stuff already in your car?
And about the leak (finding drops on the floor of your garage and smelling antifreeze), I'd get under the car with a flashlight and find out where it's leaking from.
ive only had the car for about 3 weeks now and havent added any coolant. The coolant on the floor you can clearly see that its green and is coolant im about to take a look under there and see if i cant find the leak. Im juat not sure why it would be orange in the radiator and then green on the floor. Beats me LOL
if you do have dex cool and green coolant in the car then you should flush the system and then refill with dexcool. if you can smell anti freeze check the fluid levels after a drive and see if it goes down.
