Removing ball joints from UMI LCA's
Old 08-28-2012, 05:27 PM
Blwn_by_Twins's Avatar
Default Removing ball joints from UMI LCA's
How is it done? I'm assuming a press is needed, but I wanted to check before I messed them up.
Old 08-29-2012, 08:36 AM
Anyone?
Old 08-29-2012, 06:38 PM
sjsingle1's Avatar
did you ask UMI?
Old 08-30-2012, 09:26 AM
UMI Performance's Avatar
The ball joints are pressed in just like a factory ball joint, the part # is the same as factory as well. So you are correct, you will need to press them out.
I hope that helps,
Quick Reply: Removing ball joints from UMI LCA's
