2001 Z06 corvette
2001 Z06 corvette
Ok guys new to forum, and ls based motors. I purchased this car about 3 months ago, 2001Z with 38,000 miles, cammed, supposedly dual valve springs, and it said strong retainers,vararam intake, carbon fiber bridge, and lt headers, no cats some slight oil consumption upon getting it changed from 5x-30 to 15-50 both mobil1, then oil usage seemed to stabilize and become minimal and only saw it if I was really running it hard. Started having problems with clutch sticking to floor, so had it replaced with tick performance master cylinder, speed bleed line,18lb flywheel, and complete monster stage 3 clutch kit. I noticed more ticking noise when I got it back from shop, my mechanic had it plus went to exhaust shop to get exhaust fixed up a little. So now i've had it back like 3 weeks, noticed ticking noise immediately when motor gets up to 2500+ rpms and hold it almost sewing machine like, my mechanic said it was just normal valvetrain noise with cammed and dual valve springs. I got sick and car set this 3 week period, started it up noticed some blueish smoke and car used like 1.5 quarts of oil next couple of days, kept monitoring and it seems like after i started driving it the oil consumption balanced out and i ended up putting a total of 2 quarts drove it like 200 miles and tracked it no oil consumption???? kinda crazy like maybe a valve seal is not sealing until its driven. Sorry for the long spill just trying to make sure nothing that could cause further damage to motor is occurring, ala broken valve spring, rockers, rings not sealing, any advice would be welcomed.
Isn't 15-50 just a little thick for a 38K mile engine? I know it has been used successfuly in real high mile engines.
The sudden ticking would possibly lead me to believe your shop took it out and drove the **** out of it. I'd be pulling the coils and valve covers and have a look see. I'd probably pull the rockers as well.
And I'd be looking at the plugs for signs of oil consumption.
What exactly do you mean by "tracked" it?
Ron
Ron
I took it to the drap strip for the first time just to play a little, sounds like good advice guys I think I will prepare to do valve seals, and at that point I would be able to look at springs, rockers,etc. to see if anything looks damaged. Is the valve seals something that a mechanically inclined guy with no experience with valvetrain issues can handle? Is this pretty striaghtforward what would be steps or am I better to just take back to my mechanic.
I do trust my mechanic but don't know anything about his help or the exhaust shop they sent it to, all I know is I don't recall that much valvetrain noise until after I got it back. Thanks again for the advice so far, I will look at all pug wires asap, I'll try to post sound clip as well.
Are you sure you just aren't getting used to the sound of the engine? So now its more noticeable? Man, after i installed my cam, motor sounds like a singer sewing machine. Watch this cold start video of my car, I walk around the motor, listen to the sewing machine. I did the ls7 lifters and did the trunion upgrade. No more needle bearings. My redline is 6900rpms, I race the car and have zero oil consumption
My mechanic said he thought it was fine, maybe your right, they reworked the exhaust put different midsection in possibly quietened the exhaust down a little maybe thats why i think noise is different, dunno??? I will try and get exhaust clip. Really nice looking car you have by the way. I am gonna do the valve seals and check out all items in the process, maybe there are no major issues. I dont notice it unless I am just driving normal and run rpms up 2500-3500 right about where exhaust drone goes down and this ticking sewing machine sound come out, just sounds like its on drivers side, I have not ridden in passenger side but leaning over I cant hear it over my side anyways.
