head gaskets???
Originally Posted by soundengineer
on heads install can you just use high temp RTV??? I seem to remeber seeing this done on some saturday morning car program....
just curious...
I'm probably gonna do the real gasket either way...
just curious...
Either assemble dry or you can spray on some Hylomar (what I use)
Modern engines require high-tech head gaskets. GM’s Gen III engines use MLS (multi-layer-steel) head gaskets developed in Japan in the early 1990s. You can learn more about these gaskets at the following Dupont-Dow web site:
http://www.dupont-dow.com/Applicatio...otive/head.asp
