Generation IV Internal Engine - LS2 timing cover difference? Need help
KY Nova
08-29-2012, 06:52 PM
I'm putting a F1A on my LS2 out of a 06 TBSS in a 71 Nova. I bought a 06 GTO water pump so i could put a LS6 intake on it. The problem, the water pump hits the timing cover and has about a .0050-.0070" gap between it and the block. Is there different covers? If so, what do i need?
Allen
S10xGN
08-29-2012, 07:26 PM
If it looks like this:
http://ls1tech.com/forums/attachments/parts-wanted/337817d1327944228-wtb-ls2-front-cover-dsc03723.jpg
You'll need to replace it with one that looks like this:
http://ls1tech.com/forums/attachments/parts-wanted/337818d1327944243-wtb-ls2-front-cover-dsc03725.jpg
KY Nova
08-29-2012, 07:37 PM
Thanks for the time Russ. It looks like the bottom one. I wonder if it's hitting 2 of the bolt heads instead. I could pull them and see, but there would only be a few thousandths gap between the cover and back of the pump.
KY Nova
08-30-2012, 06:52 PM
Does anyone know if that is the only 2 cover designs?
S10xGN
08-30-2012, 07:20 PM
Are you checking this clearance with the pump gaskets in place? They are metal with rubber seals and are close to 0.100" thick...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
