Fueling & Injection - Good injector for future forced induction.
DisasterpeaceWS6
08-30-2012, 02:34 AM
Currently have TFS 215s and 228/230 cam set setup with fast 102. What would bee good injectors that will be able to handle forced induction lter down the road?
stevieturbo
08-30-2012, 04:49 AM
You need to decide on final power goals, then a decision can be made.
DisasterpeaceWS6
08-30-2012, 05:17 AM
Final power no more than 700
stevieturbo
08-30-2012, 05:22 AM
60lbs may just get you there. Some 83lb Siemens or ID750's or thereabouts would be fine and leave you some headroom to be perfectly safe and future proof.
DisasterpeaceWS6
08-30-2012, 05:42 AM
So i should get 60lbs? When I got forced induction I plan on getting the procharger dsc1 kit. Some kits come with injectors and pump. So should i even worry about getting them now?
ZL1Killa
08-30-2012, 07:47 AM
or even some FIC injectors, i would save some dough and get you some 725cc or larger injectors and the ones that come with the kit wont likely give you much info
