What are the best cyclnder heads
Old 08-30-2012, 02:41 AM
vsls1wgn's Avatar
Default What are the best cyclnder heads
Hey guys wanting your opinion on cyclnder heads i have and ls1 gen 3 with a 232-234 comp cam i wanting to put some heads n pistions so id like you guys opinion thankss
Old 08-30-2012, 04:03 AM
usnfenix's Avatar
um. not sure what your asking here and im going to assume your on a cell phone.
texas speed has some good choices for cylinder heads, PRC stage 2.5 heads will do that cam nice. and as far as im assuming your asking about pistons, well, why? whats wrong with your stockers that you need to replace them?
Old 08-30-2012, 06:01 AM
ULTIMATEORANGESS's Avatar
look into MAST. not cheap though.
Old 08-30-2012, 03:11 PM
TXZ28LS1's Avatar
Most people think that the most expensive heads are always the best. That is not always the case.
Old 08-30-2012, 03:28 PM
FastFitters35th's Avatar
I have AFR. I have no complaints.
Old 08-30-2012, 07:22 PM
same here. their customer service when i had a problem impressed me.
Old 08-30-2012, 07:31 PM
"MAC"'s Avatar
call summit and ask them they will tell you exactly just give them your cam specs and they will give you a choice of like 5 different ones that best fit your application that you need also if yours is an auto make sure your cam works great with your stall i.e. my stall is a 3600 and my cam spec is 227/231 .617/621 that cam will go great with my stall since the real power starts around 3500-3600 rpms so the rep from summit suggested i get a Genx 220 heads hope this helps
Old 09-01-2012, 10:46 PM
Sales@Tick's Avatar
Trick Flow Specialties hands down.
Old 09-01-2012, 10:49 PM
Sales1@Texas-speed's Avatar
OP we have several different options to fit various needs whether your looking for CNC ported factory casting or your wanting to step things up even more with an aftermarket casting. Dont hesitate to give us a call we are happy to help.
Old 09-01-2012, 10:53 PM
Mike Morris's Avatar
How much power do you want? Future plans with the motor? How much do you want to spend?
Old 09-01-2012, 11:21 PM
My6speedZ's Avatar
^^^ This right here, threads like these are worthless without knowing what you want, future plans, and budget. Just saying "whats the best head" won't get you anywhere because best is only relative to the application.
Old 09-02-2012, 10:18 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
All-Pro, MAST, AFR, TEA, are all good heads.
Old 09-02-2012, 04:16 PM
85Iroc's Avatar
I've seen a couple of "call Summit" replies in threads lately....... Summit is NOT the best place to go for tech advice.
Old 09-02-2012, 05:10 PM
Mazzenger's Avatar
First determine your plans/goals for the car and go from there. What's your budget?
If the budget allows AFR and Trickflows are both incredible heads and are proven.
Contact Tony Mamo for AFR heads or Mike at Total Engine Airflow for Trickflows.
They are both awesome individuals and will be upfront and honest.
I have witnessed some PRC stuff do well too.
IMO.
Old 09-02-2012, 09:36 PM
garygnu's Avatar
don't swap you pistons unless you are rebuilding the engine.check out some TSP PRC cnc ported heads.
Old 09-02-2012, 09:58 PM
pharmd's Avatar
OP these guys are right, you don't build a house without a plan, and you should build a car with out a goal. Does the end justify the means, ie does spending a ton of money justify you wanting 450rwhp? Now not knowing what your goals are makes it all just guessing, but by the the question you asked and how you asked it, I would assume this is probably your first rodeo. If you are just used to a bolt on or cam only then getting a decent head, even a factory ported head on there will serve you very well. You can make 440-480rwhp with a high quality factory ported head if your shortblock is solid. This type of plan would save you some cash flow over an aftermarket head.
I would like to recommend taking a hard look at using your own heads and doing this: AI CNC PORTED 241
Old 09-03-2012, 08:43 AM
MonmouthCtyLS7's Avatar
Tea, Afr, and trickflow are all good. Not much experience w/ Mast or All-pro
Old 09-03-2012, 09:46 AM
TransAmcoupe98's Avatar
Old 09-04-2012, 07:35 PM
jbro90's Avatar
Op if you do any research in any of the heads that people are throwing out you need to look at the intake and exhaust flow numbers and compare between heads prc heads have great flow and I've seen that they ha e alittle better flow then a lot of other heads out there but they are not cheap
Old 09-04-2012, 09:10 PM
garygnu's Avatar
what can you afford ?
Quick Reply: What are the best cyclnder heads
