Knock sensor bank 2 problem
SES light is on and says knock sensor bank 2 has low voltage, probably means it isn't working.
How serious is this and is it easily fixed? The car runs fine and doesn't really knock.
Most likely needs a knock sensor. It's under the intake manifold so you will just need a set of intake gaskets and a new sensor...or if you have the extra cash just replace them both since you will be right there. Also, the connectors get very brittle with heat and age so I would also get a new wire harness too. WS6store sells both.
http://www.ws6project.com/user_stor/...-knock-sensor/
http://www.ws6project.com/user_stor/...-wire-harness/
