86 Notch lsx 402
86 Notch lsx 402
Well decided to make a new thread. Cage is in, motor is almost done (ls2 with 4.0 stroke callies crank manley pistons n rods, comp custom grind cam, l92 heads with manley springs decked .30, edelbrock vic jr with an 850 quick fuel carb n a plate with 200 shot. Would b finished but cam bearings were installed wrong so gettin them redone tommorow. Trans is finished, level 7 RPM 4l65e with a coan 3600 stahl. Has a Broke Dick racing cage, with skinnykid motorplate, n aje k member n a arms. Upr Anti rollbar and front coilover. Lakewood Dragstruts n comp rear shocks with granetelli upper n lower control arms. 35 spline spool with polished ford racing 4.10s n moser axles. rear is narrowed 1 in per side to allow the 28x10 drag radials. If all goes well i hope to b at Indy NMCA. She will still look ruff but ill get er painted this winter. Gonna run True street n Rumble!
