6.0L Engine out of a 2001 Denali
I have acquired a 6.0L Engine out of a 2001 Denali Was wondering some specs on the engine it is cast block aluminum heads. I have a long block. Thanks Daniel
It should be a LQ4 engine, bore 4.00" X 3.622" stroke, 9.4:1 CR, 364 CID, 6.0L. Pretty sure the LQ9 was not used in the Denali until 2002.
Heads will probably be 317 with 71cc chambers 2.00" intake valves and 1.55" exhaust valves.
