recommend me a cam?
recommend me a cam?
motor will be a stock 5.3 with a gt4294 turbo pushing around 15 psi initially. th400 around 3800-4000 stall probably. was looking at these cams from comp.
http://www.summitracing.com/parts/CCA-54-444-11/
http://www.summitracing.com/parts/CCA-54-467-11/
would these be good OTS cams for what im putting together?
if not can someone point me in the right direction. thanks in advance.
thank you! ill be contacting you in the next couple of weeks for a cam spring pushrod package then
