F1 procharged guys
F1 procharged guys
Im looking to start my long time build and after much debating im goin with the f1 series blower. Im looking to see what kind of combos and which f1 series blower your using.
My goals
Mid 9s in 1/4
Streetable (60% track, 40% street)
800-1000rwhp
Run on pump gas( meth as safe guard)
Thoughts i been kicking around
Aes 390 or 416. 6.0 iron based
317 heads
Custom cam
Ls6 intake for start
Lonnies two fuel pump setup
All arp hardware with head studs
Its going into a 00 trans am, with 4l80e and a mwc 9in with 3.55 gears with big and littles on 275/60 et street radials. No ac.
Thoughts and suggestions? Right now i am think a budget of 20k
My goals
Mid 9s in 1/4
800-1000rwhp
317 heads
Custom cam
As far as heads i was thinking of starting off with the 317s and when i would upgrade the intake, upgrade the heads.. I was seeing the use of prc237s by a few people and afr 225s. What about trickflows?
Im thinking the f1a would suit my needs. Agree or do i need the r or c?
May as well get the F1X if you are buying the head unit new.... Not THAT much more money but lot more blower. F1R will get you 1000rwhp if everything else is right..
A 370" motor will be fine... You can make 1000rwhp with a 370 but EVERYTHING will have to be right.
Get ready to spend some $$$....
I am doing a similar build right now and I will be at $30k once its all done..... But a lot of stuff could have been done cheaper or not at all and still make power.
I went 9.80's @ 3810# with a D1SC/402/twin intercoolers/meth/4L65E - Yank 3400/9 Moser 3.70 on a 27x11.5 Hoosier.
I have been 9.18 @ 3350 with a 347 LS6/AFR 225/baby 224 cam/TH400/3.70 Moser/FMIC/D1SC
Your goals are easily obtainable and have been done many, many times.
I would do a 370" iron or a 402" iron or aluminum, the AES 390 is fine too. Really anyone of them will do it with the F1A. No need to get exotic on parts. They all will run good, even a LS1/6 with good heads. TFS 235 heads rock, AFR 225's work well too.
No need to spend 30K, that is just down right funny there! These motors do just fine with minimal mods just need to have a knowledgeable builder do the work and assembly. Done this many times now.
Stock 6.0L iron with ARP studs, or a LS2 with ARP studs. Spending an extra 350.00 to dowel the mains would be money well spent. No need to invest in caps. LS9 head gaskets, thick deck aftermarket heads with light valves and valvetrain, stock rockers with Harland Sharp mod. Stock cranks work just fine too, if you feel you want to spend money get a Compstar crank. The Compstar H-Beams work just fine too for the money. A Diamond shelf piston is also fine. LS6 intake and you are more than capable with a F1A to go into the high 8's at 3400lbs with the right converter and chassis. My $.02
My goals
Mid 9s in 1/4
800-1000rwhp
317 heads
Custom cam
My goals
Mid 9s in 1/4
800-1000rwhp
317 heads
Custom cam
It can definitely add up though...
$11k for the engine, about $9k in the custom blower kit, $2k fuel system, $2k exhaust, $700 in valve covers, $600 in ventilation system, $500 in meth, $1500 for clutch.... Pretty much the best of the best in everything.... easy $30k..... This was not just for building big power, but for having every part of the system 100% reliable and show quality. All depends on what you want I guess.
Im not "skimping" on anything on this, but some pieces i already have and will use to get the bugs worked out and get used to everything. The two things i see holding me back will be the heads and intake, but for start up, breaking in, and new build "issues" i think they "should" work. Then once that is all done and worked out bugs, i will swap some tfs 235s and a vic jr intake with an elbow
You can make 1000hp with an LS6 intake no problem. Hell you can probably do it with stock 243s also if you can cram enough boost in it and keep the heads from lifting.
I'm running a stock LS6 intake on my new build as well.
Arun trapped 160mph with an LS6 intake at 3500lbs. (easily 1000hp).
The $1200 you would spend on a fast/TB you can put into a Direct Drive or 10 rib/ or cog setup.
Keep us posted on your build.
