'77 Trans Am With 455 motor issues..need help
All,
i finally bought a '77 trans am just like one my dad used to have, and im sourcing all the pieces i need for this LSX/T-56 swap i am going to do...
However in the mean time i have been trying to make the 455 in it work..
I got it two start three times and that was it...
Things i have done..
-Compression test. all cylinders at 130-150
-new starter
-new alternator
-new belts
-new water pump,
-new cap/rotor DEI/wires/plugs
-battery
-new oil (old oil had some gas it it)
The issue it has is that the motor turns over EXTREMELY slow, i only seem to have had enough juice to start it when i had it hooked up with jumper cables.
That was the only time i was able to get it running. When it did run i had to give it some gas, but any more than quarter throttle and it would start to flood out and then die.
The last time it ran when it was running i heard some sort of squeeking metal noise, and then the motor stopped.
I can barely get it to turn over now...
Any suggestions? I was just hoping to get this motor running to drive the car around while i get all my motor swap pieces together.
Thanks for your suggestions in advance.
-Chris
-new starter
-new alternator
-new belts
-new water pump,
-battery
-Chris
I tried to jump start it again since i put the new alternator on yesterday, and i can barely get it to turn over. The starter is trying but the compression is too much.
The last few times it did run, it barely ran and was making a squeeking noise and then just died. seems like something internally may be having a hard time spinning...
i was planning on check the rocker arms next. Then possibily the oil pump and timing chain.
... but i will check all the power connections again... However i believe them to be fine. It was the first thing on the car i had to fix when i got it.
Check the rockers- on a pontiac motor they are a set torque rating- non adjustable but the lifters will need to be full of oil to tighten
Mist likely it is the starter and cables. I do a lot of old pontiacs and they chew up starters cause they run hot.
Buy a Hi-torque mini starter and run '0' gauge cables for positive and neg- this cures the problem 90% of the time
If you are convinced that it is NOT a bearing or other internal engine problem, be sure you use a BIG battery w/ alot of CCAs. Even my low-compression '76 455 had a hard time turning over until I put in the biggest battery that would fit. You didn't mention what year the 455 was from, if it was a high compression '70 engine, the cables in that '77 TA may be under-sized for the task of delivering enough amps to turn over a high compression big cube engine.
Well the down side is the guages dont work...when i got the car it didn't have any power what so ever. I had to fix the wiring.. It's very small gauge electrical wiring for sure.
When i did get the car started i had jumper cables attached with a truck running. that helped get more power to turn it over. It started making a noise similar to my buddies Ls2 goat when the oil pump ate itself. Then the car shut off.
I took the plugs out, drained the oil. put fresh oil in. Didn't see any metal. But did smell gas.
I did a compression test, and the motor turned over fine without the plugs in. But once they are in i can barely get it to turn.
I changed the water pump because it was leaking, and put a new alternator on. Thinking this may have been partial to the problem. But that didn't fix anything.
I have no idea what year the motor came out of. I did verify its a 455 though.
I'll see if i can post the short video clip i have of the car running and dying to show you all..
What cylinder heads are on there? There's a code on the middle 2 exhaust ports. All the 455's have flat top pistons unless changed by someone. If you have high compression that can be an issue. Make sure your rockers are adjusted properly too.
the head code is 6191.
the gas i smelt was in the oil.
Also i was able to spin the crank by hand.. but barely. 1/4 inch at a time.
Here is a website that will show you where to find the codes they are looking for:
http://www.wallaceracing.com/head1.htm
Sounds to me like you are running way too much advance... This happened to me when I first got into Pontiac V8's; they are very picky about ignition advance timing.
My Pontiac motors act the exact same way when I advance it too much.
A quick check would be to unplug the wire going to the distributor and then turn the engine over... if the engine turns over much more freely now you have your issue.
