Buying LS1 Advice needed
I found an 01 SOM 6spd SS, looks like its in good shape body wise. It already has a 12bolt rear w/4.11's and a cam, trans was recently rebuilt. The guy said it needs a new torque arm, how hard is the install on that. I looked around online and it looks like they cost anywhere from $200-$500 is that correct? He is asking $9999 OBO what would be a fair price to pay? Also has 101K miles.
Thanks
Thanks
torque arm wouldn't be bad at all to replace, and you can check them out here!
http://www.ws6project.com/user_stor/...g/torque-arms/
while you change the torque arm, might as well go a little further and swap the tranny mount to poly if the car doesn't already have one
Thanks
Thanks
I'd start negotiating at 8. i think 9999 is a little high for something with that many miles that needs a torque arm. But, I just did a clutch in my car, had to pull the aftermarket torque arm, and it was a pain in the ***, it wasnt hard by any means, but just getting the bracket off on the tranny was a pain because the bolts were so long that the bracket got stuck up against the tranny tunnel. However on my 02 ws6 its a two piece bracket and we got it apart and got the torque arm out of the way.
