Predator-Z El Torro Cam
Was looking at your 230/230
Wondering how this would work for my cam only set
LS6 or FAST 90
LT's
UD Pulley
4000 stall
4.30's
28" tires
3500 pounds
Looking to run in the 11's
These are the numbers needed to order
Intake lobe # 3016R
Exhaust lobe # 3725R
111 LSA
109 ICL
Also what springs to use with it??
Run a 7.4 pushrod
LS6 or FAST 90
LT's
UD Pulley
4000 stall
4.30's
28" tires
3500 pounds
Intake lobe # 3016R
111 LSA
109 ICL
Run a 7.4 pushrod
LS6 or FAST 90
LT's
UD Pulley
4000 stall
4.30's
28" tires
3500 pounds
Intake lobe # 3016R
111 LSA
109 ICL
Run a 7.4 pushrod
LS6 or FAST 90
LT's
UD Pulley
4000 stall
4.30's
28" tires
3500 pounds
Intake lobe # 3016R
111 LSA
109 ICL
Run a 7.4 pushrod
Pushrods will have to be measured.
I'm interested in the toro too. But I'll be running a ss3600 3.23s ls6 mani and p/p 241s.
I'm planning on running a tsp 370 later how would this cam perform in said 370?
There is more to a power-curve than just a percentage of intake flow. One has to observe what all the valve events do for each other and what is the result of that symbiosis in the power-curve. Highest peak hp does not necessarily mean quickest.
