315s or 275s drag radials what size is better??
Old 09-04-2012, 08:06 PM
unioncarpenter84's Avatar
Default 315s or 275s drag radials what size is better??
im running the american racing tt2 the 10.5s in the rear looking to buy drag radials which is the better size to go with for the track on my wheels??
is there a difference?
Old 09-04-2012, 08:08 PM
cookba's Avatar
you have TT2's as a track wheel? thats a lot of weight. anyways, stick the 315's on there though the 275 would put you in a x275 bracket class.
Old 09-04-2012, 08:20 PM
its just a street car just take it up the track prob ten times a year
Old 09-04-2012, 08:25 PM
cookba's Avatar
if you dont have the power to turn and burn a 315 then stick with a 275.
Old 09-04-2012, 08:27 PM
i got 12.41in a quarter on a set of bfg drag radials and 1.6 sixty foot
Old 09-04-2012, 08:34 PM
cookba's Avatar
275's aired down to 16-20psi and you'll be good. suspension has a lot to do with how well your tires will do there job too.
Old 09-04-2012, 08:40 PM
02TransAm/Batmobile's Avatar
Why are you limiting yourself to those sizes? If you have a 10.5 width, that's kind of wide for 275. Why don't you look into 305's or 295's?
Old 09-05-2012, 03:12 PM
what brand of a tire sells 295 or 305 i havent seen any just 315s
Old 09-05-2012, 03:58 PM
Latch's Avatar
A 275 will look rather stretched on a 10.5" wide wheel. Go with a 315.
Old 09-05-2012, 04:23 PM
01'SSLSX's Avatar
nitto sales a variety of sizes. the NT05R and 555R
i use the NT05R 315/40-18 its Awsome! but its a lil big, i will change to a 555R 305/35-18 soon
Old 09-05-2012, 04:26 PM
i got 17s tho
Old 09-05-2012, 04:27 PM
01'SSLSX's Avatar
not as much as you would think. im running 10.5's all the way around and used 275's for my front. it barely stretched, but it would look flush with 285's
Old 09-05-2012, 05:15 PM
backdraft408's Avatar
i have a 10.5 rim with 315s
Old 09-06-2012, 01:18 PM
redtan's Avatar
Maybe you have a wider running tire, or have a varying definition of what looks stretched.
I've seen a 275 on a 10" and it looks stretched with the lips of the wheel showing.
Old 09-06-2012, 01:24 PM
RoidedSS's Avatar
the look alone of a 315 would be worth it if the price wasn't too big of a concern. I would have to agree, a 275 would look stretched on a 10.5 inch rim. My 275's on a 9.5 inch rim sits flush....I would run a 315 or a 305. Toyo proxes r888 comes in that size along with the nitto nt05r i believe
Old 09-06-2012, 09:25 PM
cookba's Avatar
ya forgot they were 10.5 wide. you'll need something larger than a 275, I think the NT05R comes in a 295...........
Old 09-08-2012, 04:10 PM
69TA's Avatar
Definately not a 275 on a 10.5" wheel
I personally would go with a 305 on that wheel
or 315 as a second choice.
Old 09-09-2012, 08:32 AM
ya ill be going with the mt 315 drag radials
Old 09-09-2012, 08:37 AM
mikh338's Avatar
something to remember is nittos 315 compared to say a mt 315 are not the same width. there was a big thread on this. the nittos are not as wide. i run the 315 nitto drag radials on my car without any rubbing issues etc. the other brands may require the bfh mod
Old 09-09-2012, 09:14 AM
i dont mind doing the bfh mod but i dont wana roll my fenders u think theres a need for tht with the other brands
Quick Reply: 315s or 275s drag radials what size is better??
