Best lowering spring?
I like the BMR springs. I was deciding between BMR and Strano. After looking at a friends car with Strano springs his back end sags in the rear. Looks terrible with the front sitting higher than the rear. His are about 3 years old and had the rear sag after a few months. I've had the BMR's for about 2 years and they still have an awesome stance.
I would definitely go with Strano's if you are looking for the best all around lowering spring.
i had the prokit first, car sat badass but the springs where little to soft for my liking, swapped over to BMR, car sits about the same, maybe a hair higher in the rear but much more stiff all around which i prefer
you can't go wrong with BMR or Strano, you'll probably want to stay away from Eibach Sportlines if you want to keep any kind of ride quality.....
i like the BMR's best.....their rates are a little bit higher....the guy with the sagging rear most likely has Eibach Pro-Kit springs.....this is what my car had on it when i bought it, the rear sat lower than the front and i hated it.....every time i hit a bump in the road, the rearend would hit the bumpstops.......Pro-Kit's are known to sag......i threw BMR rears in and have been happy ever since
best shock but not breaking the bank
My buddy has some BMR and i love the stance it looks even from front to end
I will be replacing the shocks on my bird but I want a good shock but i also dont want to break the bank so which on is a good brand or shock? I already got progressive spring by summit racing with a 1.2 drop i know its not the best spring out there but it was a gift so cant complain
