Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
FS - 2007 L92/LS3 Engine and ECU
Old 09-04-2012, 10:42 PM
Lurk's Avatar
Default FS - 2007 L92/LS3 Engine
Category: Engine - Complete Motors
Price: $4000
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): TX
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Long Block
Rebuilt stock bottom end (07 L92), new Bearings, Crank 0.010 under on all surfaces. Stock pistons, rods, rings etc.
Melling oil pump 10295
VVT eliminated
Aftermarket Cam slightly lumpy big lift custom grind
Ported heads L92 surfaced for compression
Ministarter
F-body LS1 oil pan and Improved performance baffle
LIFT __ 100 200 300 400 450 500 550 600 650 700
Intake _ 71 148 222 275 297 317 332 343 350 323
Exhaust 51 108 152 190 208 217 223 228 231 235
peak cam lift on the custom cam is 0.630
Patriot Extreme titanium retainers, dual springs good to 0.660
$4000
Located in Austin
Attached Thumbnails FS - 2007 L92/LS3 Engine and ECU-dscn0801.jpg
Old 09-11-2012, 01:04 PM
Lurk's Avatar
Thanks!
Old 10-17-2012, 09:19 PM
Lurk's Avatar
bump~
Old 04-03-2013, 12:16 PM
Lurk's Avatar
L92 with LS3 intake and VVT delete
LS1 Fbody FEAD
GMPP Harness and ECU
$6000
Old 04-05-2013, 09:12 AM
Lurk's Avatar
Calls returned. PMs answered. Been crazy hope I didn't miss anyone.
Old 04-09-2013, 09:18 AM
Lurk's Avatar
FEAD is as follows
Fbody style system
alternator (200 amp truck alt) DR44
power steering pump
waterpump
tensioner
all associated brackets, all the bolts
a/c compressor bracket/tensioner and mounting bolts
Balancer
Everything except the a/c compressor.
I'll take $500 firm for it.
The GMPP harness is as follows-
Description
  • Includes All the components required to run your GM Performance Parts crate engine.
    • Controller*
    • Engine Harness
    • Mass Air Flow Meter
    • Mass Air Flow Meter Mounting Boss
    • Accelerator Pedal Assembly
    • Oxygen Sensors (Qty 2 Per Kit)
    • Oxygen Sensor Mounting Boss (Qty 2 Per Kit)
    • Instruction Sheet
  • For individual engine controller, use part number 19201859
*Note - This controller will not function in a production vehicle unless all kit components are used and will not operate production gauges.
See the link for a video and more info. http://paceperformance.com/i-6255503...s-sensors.html
$800 firm
Old 04-09-2013, 09:20 AM
Lurk's Avatar
Engine as follows-
VVT eliminated
Ported LS3 intake manifold
Ported Throttle body (DBW)
Ministarter
$4500 firm
Old 04-09-2013, 03:43 PM
Lurk's Avatar
FEAD is SOLD
Fbody style system
power steering pump
waterpump
tensioner
Balancer
I'll take $500 firm for it. SOLD
Old 04-09-2013, 05:26 PM
KingPin1094's Avatar
Willing to sell just the oil pan?
Old 04-09-2013, 06:51 PM
Jadedbird's Avatar
Willing to sell just the short block and no oil pan?
Old 04-10-2013, 08:37 AM
Lurk's Avatar
yes, if someone bought the engine without it.
Let's see what jaded has in mind.
Old 04-10-2013, 08:58 AM
Lurk's Avatar
PM back to you
Old 04-11-2013, 12:35 PM
Lurk's Avatar
PMs replied
Old 04-13-2013, 07:39 AM
Lurk's Avatar
ECU\ Harness SOLD
FEAD SOLD
Still have an Engine
Engine as follows-
VVT eliminated
Ministarter
$4500 firm
Old 04-13-2013, 10:38 PM
Lurk's Avatar
Here are more details-
Clevite MS 2199 A-10 on mains
Clevite CB 663 A-10 on rods
Cam motion custom camshaft
Manley 1 piece chromoly pushrods 7.4" x 5/16 x 0.080 wall
Melling 10295 ported and coated high pressure oil pump
GM LS7 lifters
LS2 lifter trays
6.2L MLS head gaskets GM
GM 2nd design head bolt kit
clean and inspect heads
competition valve job
mill heads
assemble heads
Right at $1700
Also has a new fbody pan with 'Improved racing' baffle
LS3 ported intake manifold, injectors
LS3 ported throttle body
Stock block, checked and cleaned. No work needed
Stock crank 0.010 under
Lingenfelter timing set to eliminate VVT
LS3 front cover
L92 Valley cover
L92 rear cover
L92 heads 5364
L92 coils
L92 valve covers
L92 pistons and rings, standard
L92 Rods and bolts
L92 rocker arms and stands
Head flow after porting
Old 04-18-2013, 08:55 PM
Lurk's Avatar
Still pulling the items and shipping as they come off, it's been slow going due to bad weather. Please email if you have any concerns!
Old 04-23-2013, 12:08 AM
1sicksuv's Avatar
Price on l92 themselves?
Old 04-23-2013, 12:39 AM
Lurk's Avatar
Are you asking for a quote on the heads?
Old 04-23-2013, 02:52 PM
1sicksuv's Avatar
Yeah looking for some L92 heads
Old 04-23-2013, 04:11 PM
Lurk's Avatar
For the heads, ported (flow sheet) valves, rockers, valve covers and Patriot rev kit COMPLETE!
$1000 plus shipping.
Quick Reply: FS - 2007 L92/LS3 Engine and ECU
