Notices
smooth bellow
Old 09-05-2012, 03:41 PM
DIRTY_WS6's Avatar
Default smooth bellow
need any type of smooth bellow...
Old 09-05-2012, 09:43 PM
screamnbird01's Avatar
Default smooth bellow rig!
just a thought, but if you go to atwoods or most farm supply stores you can buy a straight 3in by 3in couple thats like heavy duty rubber like a 1/4 -1/2 thick for like $7 .... ive been running one on my set-up for about a year and a half now and use's less room then a smooth bellow would and has less restriction then a smooth bellow. save yourself $50 ??
Old 09-06-2012, 03:51 PM
DIRTY_WS6's Avatar
Did u have to modify that piece at all?
Old 09-06-2012, 04:50 PM
no modifying , its actually a clean looking mod. i mean it honestly looks like just a huge *** factory rubber couple... and its straight as a arrow... no restriction and its a shorter piece compared to the SLP smooth bellow also come with the bands you will need to clamp down on throttle body and mass air meter.
putting it on is a bitch tho ... you will want to boil some water and put the couple in the hott water to loosen up the rubber to slide it over the throttle body but after the first time the piece takes shape so removal afterwards and installing is a giffy!!
way better then paying 55 or 60 or 65 dollars... just minus the slp logo!
Old 09-13-2012, 02:20 PM
DIRTY_WS6's Avatar
Does itt hold up to heat well?
Old 09-13-2012, 04:59 PM
LASTOFTHEBREED02T/A's Avatar
Yes it does... I currently have a 3'' Fenco rubber coupling from Home Depot
The crap works great! lolz
You are going to make a few cuts on the coupling to get the right angle. Once you start messing with it, you'll know where to cut. Somewhat of a diagonal cut on both ends.
And if you mess up, your only 6 bucks out of pocket. Good luck
Quick Reply: smooth bellow
