Finally did it!
Finally did it!
Well, i finally purchased my turbo setup! not all of it, but most of it. Got the complete Hotside/coldside with an on3 76mm turbo. Only parts i have left to order is the wastegate, BoV, and fuel setup! Build thread will follow soon! here is what it consist of
1999 Camaro SS M6
Forged 347 -9cc Mahle pistons
Scat rods with ARP bolts
Stock crank with ARP studs
TSP Oil pump
ls2 Timing chain setup
ls7 lifters
I'll be using stock 317 heads with .650 lift springs and an 02+ ls6 cam with ls6intake with 80lb injectors
Walbro Dual intake pumps that i'll be ordering from Huron speed
If my math is right i should be right at 8.9:1 CR. Im hoping to make 600+ rwhp
1999 Camaro SS M6
TSP Oil pump
ls7 lifters
I could always mill the 317s i have! sort of new for me, im used to high CR and the dope. this motor was already built this way for boost, came with the roller i bought.
Well, decided on keeping the 5.3 heads on it, to keep the CR around 9.85:1 CR. I think this CR will be more ideal, that way the car isnt a complete dog. Opinions? Is this ideal for 600-700 rwhp?
I'm an LT1 fan(underdog all the way) but the thing that amazes me is the LSx family of motors being able to be tuned to put out amazing numbers. I'm sure the guys here can point you to a tune commensurate with your configuration to make more HP than you can probably put to the ground on a street car. My own car is like 8.5 cp and she's weak off idle till I get into boost so I think the quest to keep your CR in that 9.x strata is a great recommendation/goal. Congrats on the new setup. You're gonna love it!
