Injector Advice needed
This is my first efi build ever and I'm lost when in come to injector sizes. Advice is much appreciated..
My specs:
LS2 block
L92 heads
LS3 intake
A1000 pump
Holley HP efi
10psi from Percission turbo
Thanks in advanced!
My specs:
LS2 block
L92 heads
LS3 intake
A1000 pump
Holley HP efi
Thanks in advanced!
I also ran the Siemens 80 lbs with almost the same setup except a Harrop 2.3 on 16 lbs of boost. Currently running ID/Bosch 2000's at 23 lbs on a 4 liter Whipple snorting E85. Running out of pump though, the A1000 cannot keep up
