AbS Toner Ring?
Old 09-07-2012, 09:32 PM
1slowLTWON's Avatar
Default AbS Toner Ring?
Hey guys, i have recently took my rear end out of my 96 ss camaro which has torsen differential which i am not happy with after seeing two big cracks on each side of it but i am installing a new gear and i had to get a new carrier so i went with a eaton posi and wanted to know what the easiest way to put the abs toner ring back on the carrier. I have tired everything to heating it up and tapping it on and everything. Any one have good luck with this?? Thanks
Old 09-08-2012, 07:18 AM
FirstYrLS1Z's Avatar
Old 09-08-2012, 04:29 PM
1slowLTWON's Avatar
Actually i have even tried that and didn't have that same luck as you did. Im just trying to figure out the easiest way because i bent my first toner ring and my other one is one the way and i don't want to bend another one. Thanks
Old 09-08-2012, 04:34 PM
msydow's Avatar
how have you heated it? i use a torch with a small tip and tap them on with a hammer.
Old 09-08-2012, 04:51 PM
1slowLTWON's Avatar
With a space construction heater got it pretty hot i though but seemed like as soon as it touched the carrier it cooled down to quick i believe im going to try and use the torch next.
Old 09-08-2012, 04:55 PM
msydow's Avatar
just keep the torch moving on the inside of the ring keeping 2-3 inches from the tip to the ring. i usually spit on it or drop water on it while heating it. when the water jumps right off and sizzles it should be hot enough. just keep the torch moving.
Old 09-08-2012, 04:56 PM
1slowLTWON's Avatar
ok i will try it! Thanks
Quick Reply: AbS Toner Ring?
