adjustable fuel pressure regulator after install
i recently installed holley rails and dual walbros for my turbo setup and went with an aeromotive adj boost ref fpr. question is when i turn the key before i start the car to prime the line it's bleeds back down to 0 pressure almost immediate after pumps shut off. is this normal or should it just hold pressure? at least for a minute or so?
id image that without the engine running that it will bleed back within seconds since its a return system now. im not 100% sure. Are you seeing constant pressure with the engine running?
it was a "return system" before, too, just maybe not adjustable and at the rails. maybe 0 psi is normal, but I find it odd. the regulator is only supposed to return any (and all) pressure above what you set it at. so if your pump pushes enough volume to where the regulator sees 80 psi, but you only wanted 58 psi, then 22 psi bleeds over into the return line... at least thats my understanding
