Help with Degreeing a Cam
Having trounble Degreeing new cam
cam is a lunati voodoo vdls-277
cam card reads
lobe separation 113
109 centerline
with 4 advanced
Intake opens at 4.5
Now when i measure the lifter a .050 i get 0.5
and when i use the centerline method i get 118
Can anyone tell me if this sounds right or if i need adjustable gears?
cam card reads
lobe separation 113
109 centerline
with 4 advanced
Intake opens at 4.5
cam card reads
lobe separation 113
109 centerline
with 4 advanced
Intake opens at 4.5
cam card reads
lobe separation 113
109 centerline
with 4 advanced
Intake opens at 4.5
How are you setting TDC on the wheel?
Can you post a picture of the cam card?
Stock timing set with c5r chain
I'm lining up the dots on the gears then puting the piston stop in and rotating it fowards and back getting it to true top dead
Im 98% sure im doing it right. Seems to me like i need to advance it 4 degrees just not sure
You can get an adjustable gear set, or you can get a bushing kit and lock plate, you already have a nice chain, so the bushing kit will save you some money. You will need a drill press though to modify the cam gear.
Select the appropriate bushing and use trial and error until you get the ICL to match what the cam card specifies along with matching the other noted valve events on the card, IVO, IVC - default to the specific opening and closing event should there be a discrepancy - some lobes do not allow accurate degreeing with the ICL method.
i bought a rollmaster adjustable gear set and advanced it 4 degrees now the IVO and IVC are spot on but the ICL is now at 113 should i advanced it another 4 to get it to 109 or leave it?
