Supercharged 402ci GTO For Sale
STF Veteran
Year: 2006
Make: Pontiac
Model: GTO
Price: $30000
Mileage: 40500
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Gray
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
- Fully forged, ARP 2000 rod bolts
- Wiesco forged pistons with steel top ring
- Eagle rods
- Eagle 4340 Steel Crank
- Cometic head gaskets
- ARP Head Studs and Main Studs
- Ported and shimmed oil pump
- Trick Flow 225 CNC heads
- BHP custom grind Blower cam [will release specs with serious buyer]
- Double Roller timing chain set with billet gears
- Hardened push rods
- Yella Terra roller rockers
- LS7 lifters
- Lonnie's performance return style fuel system with twin 255's in tank
- Fuel Lab filters and regulator
- Braided Teflon fuel lines
- Billet fuel rails
- 60# injectors
- Pacesetter long tube headers, off road Connector pipes, factory cat back
- Procharger stage 2 intercooled supercharger system with D1SC head unit, dedicated 8 rib drive system
- Big Red Race Valve
- Snow performance methanol injection system
- Built 4L65E transmission with Precision Industries Vigalante 3500 stall single disc lock up converter.
- Heavy Duty external Trans cooler
- M/T 265 Drag Radials
- Auto Meter Sport Comp 2 fuel pressure and boost pressure gauges mounted above the center vents in a custom gauge pod.
- AEM wideband A/F meter.
The car was Dyno Tuned by Jeff Rhodes at Mayhem Motorsports in Raleigh, NC, and made 620 rwhp on a very conservative 9 PSI on pump gas, before the meth, and through an unlocked converter. The car runs and drives like stock with cold AC and all. there is way more left in this car. Just turn up the boost! The interior and exterior are both 9.8 / 10. It has been to 2 shows thus far, and brought home trophies from both.
Asking 30k
Please call 919-730-7227 and ask for dusty
