Machining Question?
Machining Question?
I see all this talk about flycutting on here and was wondering why not just turn the face down on a lathe? As an ex-machinist i always had better results with turning round parts rather than flycutting. Does finish have something to do with it or are they usually ground smooth after? And what finish number is required? I'm curious because I'm looking at putting L92s or LS3s on my LS2 and I have been reading about some PTV clearance with big cams on these heads. I have access to both a bridgeport and a lathe (even an old shaper which gives a great finish) and may end up having to do this...Thanks in advance to anyone with some input!
We only face the top of the piston in the lathe in order to reduce compression height in custom applications, for valve reliefs we mount the pistons in a special vise and cut the valve reliefs with indexable flycutter. Sometimes we use the CNC to cut special dishes or reverse domes in the crown as well.
Thanks for all the clarification. I doubt with this build I am going to cam it that big that I need to do so, but for future builds I may or may not start getting into that. As crazy as it sounds because building an engine is a headache in its own, it's still my stress relief learning about different builds and I want to get a little deeper into things in the future. Thanks again guys! Appreciate the input!
Edit: Meaning not as big as their biggest for these heads, I was a little unclear on that
