Moser 9'' 31 spline axles how much hp?
Old 09-10-2012, 09:51 PM
StangBanger317's Avatar
Default Moser 9'' 31 spline axles how much hp?
So I recently got a Moser 9'' w/4.30 gear, spool, and 31 spline axles in my M6 Trans Am.
My question is on an ET Drag will I twist my 31's? How much hp are they good too? Right now the car sits at 408/392 but will be closer to 450 next week and then nitrous..
Just wondering how much strain they are good for on an M6
Old 09-11-2012, 12:11 AM
CamaroZ28_LS1's Avatar
uhhh your kidding right???
I am making over 5xxwhp and launch the ever living hell out of my 9"... **** ain't gonna break. Axles are good for over 1000hp lol.
funny you made 408whp, I made 404 on motor with the same combo well w/ the 224r cam and Fast 90 w/ 92mm tb/ LS6 heads through my 9" rear before i did the blower.
Old 09-11-2012, 03:06 AM
35th SS's Avatar
you aint twistin those 31 spline.youll break/snap sometin else like your ujoint unless they are solid with no grease fitting.
Old 09-11-2012, 05:16 AM
My6speedZ's Avatar
Goto brute speeds website and find the axles ad and there is a formula that will tell you the value of your car leaving out of the hole and then compare that to what each axle is rated at.
Hope that helps
Old 09-11-2012, 07:27 AM
3fingas's Avatar
I got 35s lay'n around, if you ever want to swap them out.
Old 09-11-2012, 08:07 AM
My6speedZ's Avatar
I though the cases were different for 35/4O's vs the 28/31/33
Something to do with not being able to fit the bearings for the 35's into the smaller case.
Old 09-11-2012, 08:40 AM
I've just heard that the Moser 31's on an M6 car with a sticky tire had give people problems in the past.
Getting ready for a 402 w/P1SC so sure hope it holds
Old 09-11-2012, 10:37 AM
My6speedZ's Avatar
I saw a thread where a guy spun the 31's over I'll see if I can dig it up.
Old 09-11-2012, 10:38 AM
Would like to read up on that
Old 09-11-2012, 10:47 AM
My6speedZ's Avatar
The one I found before was talking about trac-loc. Guy had 31 spline trac-loc posi and he was getting one wheel burnouts because of bad clutches. Wasn't a problem with the splines. My bad
Old 09-11-2012, 12:29 PM
3fingas's Avatar
Not true. Small GM end with big ford bearing
Old 09-11-2012, 01:00 PM
My6speedZ's Avatar
Care to be a bit more specific I don't understand.
I thought there were two cases
3.026" bearings for 28-31-33 spline centers
and 3.25" bearing for 35-40 spline centers
That was the way the guy at Quick Performance made it out, said if I ever planned to go up to 35 since I was M6 then I should just start there and eat the cost, because it would cost the same amount to do it over because I would be buying the diff and case and axles to go 35 later from say a 31.
Old 09-11-2012, 05:01 PM
StraightTimeStirrups's Avatar
Read #7
I dont know about other companies stuff but I found this doing some other research.
Joe
Old 09-12-2012, 08:24 AM
3fingas's Avatar
switching from 35 to 40 is the problem. IIRC the 40 axles are bigger which requires a larger end for the bearing. If you dont switch the end then a thinner bearing is used which can be problematic.
Let me know if your interested. LOL
Old 09-12-2012, 12:55 PM
My6speedZ's Avatar
3fingas you've got PM
Old 09-14-2012, 04:43 AM
I have this same set up. one day when the trac loc wears out, I will get a built center section again with the aluminum housing and a spool or the wave track. take some weight out of it.
Old 09-29-2012, 04:36 PM
Duffster's Avatar
If I'm not stupid, I think I found some spools to handle the 35 splines using small bearings on our favorite auction site...
Old 09-29-2012, 07:00 PM
You can run a 35 Spline Axle in a Small Bearing Case with a Mark Williams Spool that is made for that application. I'm not sure if it requires Mark Williams Axles or Stock Type Splines!
Joe
Old 09-30-2012, 12:25 PM
stevieturbo's Avatar
I twisted a few 31 spline Moser shafts on my 8.8". I ended up with Mark Williams shafts and they're working great.
Although at only 400hp or so, I doubt they will ever come to any harm no matter what tyres you use.
Old 10-01-2012, 08:34 PM
BIGDRAGON's Avatar
I'm looking to purchase a moser 9" I'm at 546rwhp with the juice, what spline's should I be looking at?
Quick Reply: Moser 9'' 31 spline axles how much hp?
