Huron Speed "Hotside" Turbo Kits Available!
After many people asking, we are now releasing just the hot side components to our truck manifold turbo kit! Most of you already know the drill, but for those that do not, being that this is for a truck manifold application, you will have to remove the A/C, remove or space down the front sway bar, and relocate the alternator. These are the same components in our complete kits!
These kits are IN STOCK & Ready to Ship, ZERO Wait Time!
** All Components are 321 Stainless Steel, Tig Welded, and polished.**
With this, you will receive the following components:
-321 Stainless, polished, Crossover pipe with T4 Turbo Flange and 38mm 2-bolt Wastegate Flange
-321 Stainless, polished, 3" V-Banded Down-Pipe with 3" V-Band at opposite end for easy building off of
-Gasket Kit including gaskets for all 4 connection points on the crossover pipe (2 truck manifold connections, turbo, and waste gate)
Pricing:
Standard pricing is set at $999 for the kit, however we will be running an LS1tech special through the month of September for $769.99
How to Order:
CLICK HERE TO ORDER FROM OUR WEBSITE!
If you are interested in our Complete Truck Manifold Kit, please CLICK HERE TO VIEW IT ON OUR WEBSITE!
Pricing:
How to Order:
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
TWITTER @HURONSPEED
TWITTER @HURONSPEED
I was just thinking that myself, maybe consider mocking that hot side with a t6 flange just so its available. I really nice thing to do would be make a 4inch dp starter for the all so common Borg warner turbos and maybe a 4inch for a t6 Garrett based turbo......cover a wide range of setups for many people that way. I imagine pricing could be very similar just have to take into account that the v-band flange for those maybe a tad more expensive and the 4 in pipe will be a little more.
are you going to be wanting just the hot side? or a complete kit?
__________________
TWITTER @HURONSPEED
TWITTER @HURONSPEED
Thanks! For this hot side set up, this is currently the sale. intro special at $769, normal pricing set at $999, so now is the time to buy!
__________________
Thank you, we appreciate it!
__________________
No there is not, however if needed I can do the crossover in a T6 flange. PM me for more info.
__________________
__________________
Thanks for the orders All current orders are SHIPPED!
__________________
All PM's replied!
__________________
