aluminum drive shaft
Old 09-12-2012, 04:06 PM
sparkwirez06's Avatar
Default aluminum drive shaft
How many of you have bought a custom length aluminum driveshaft? How was the quality of the welds?
http://www.syty.net/forums/showthrea...=86244&page=10 I would post pics but my upload problem is unresolved. there are pics in the link.
Old 09-12-2012, 04:30 PM
85MikeTPI's Avatar
Hope you got a good price.. :/
I've had 4 custom shafts made by Denny's Driveshafts and nothing ever looked like that..
http://www.eecis.udel.edu/~davis/z28...391_large.html
Old 09-12-2012, 04:44 PM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
Looks like a standard MIG welded Aluminum driveshaft; although I would say their QC is a little low and wire feed was too fast.
I'm in the same boat as 85MikeTPI; All the custom shafts I've ever gotten were from Denny's Driveshafts and looked like the one he posted for the aluminum ones. His steel ones are closer to the one you posted build-up wise, but cleaner in weld quality. I ran/will be running a Nitrous Ready on my car (Guaranteed for life!)
Old 09-12-2012, 07:23 PM
leon phelps's Avatar
grinding off the splatter would make it look way better.
the welds look fine, plenty strong, good penetration to both sides.
Mig welding aluminum is not easy. guess the guy does not have the coordination to tig. I know I do not.
Old 09-13-2012, 03:07 PM
If I grind off the splatter, the shaft would need rebalanced.
Old 09-13-2012, 03:38 PM
Stormed_Norm's Avatar
Guess you went in on that group purchase. I didn't think it was a great deal. Nothing I couldn't get done locally. That splatter should have come off before it was ever balanced.
Old 09-13-2012, 04:46 PM
Denny's Driveshafts has a custom built proprietary welding system they have developed for doing their welding; none of their shafts are welded by hand.
Old 09-14-2012, 01:07 AM
gnx7's Avatar
I just had 2 alum dshafts made with 31 spline yokes, 1350 Spicer Ujoints, 3.5" tubing and they said a machine does the welding.
Mine didn't have splatter like that; however I wouldn't worry about it unless you have a trailer queen and a powdercoated frame
take it to the strip and let it rip! That splatter is purely cosmetic. They should've knocked it off/down but it isn't the end of the world.
Old 09-15-2012, 12:35 PM
gto866's Avatar
People have a lot of problems with aftermarket shafts -mine was vibration. Research customer satisfaction on your intended purchase
Old 09-15-2012, 06:32 PM
GuildJS's Avatar
i got an aluminium drive shaft and that crap cracked after 10 miles
Quick Reply: aluminum drive shaft
