fast 102 sensor placement
Old 09-12-2012, 09:49 PM
1bd63nova's Avatar
Default fast 102 sensor placement
i have a 6.0 liter 2003 lq4 and im putting a fast 102 intake trick flow 220's and a flr1 procharger im confused on where i should place all my sensors for a boost app. the stock location? any pics or ideas would help ive done searchs couldnt find what i wanted thanks
Old 09-13-2012, 11:05 PM
95ONE's Avatar
Stock ECU with a Tune, or aftermarket?
MAF before blower. - unless Speed density program, then throw away MAF and don't worry about it. Recirc blow off valve to intake if using MAF, unless Speed density. If Speed density, blow off to atmosphere. Air temp and MAP, at the intake manifold. MAP sensor must be rated to at LEAST the pressure you plan on running. normal atmosphere- no boost = 1bar.. 14.5psi = 2 bar. 29psi= 3bar. All others in stock locations should be fine.= TPS, Crank, Cam, Pressure, Coolant, etc.
Old 09-13-2012, 11:10 PM
derrickman05's Avatar
I put the map sensor on the back and so fat have broken 2 smooth off. If I could do it again I would put it on top and buy an extension.
Old 09-14-2012, 12:21 AM
1bd63nova's Avatar
no mass air.. ill post pics tomorrow
its gonna be low boost stock computer from a 6.0 fast intake 80 lb injectors trick folow 220's blower cam 2 in headers and about 8-10 pound of boost street car nova
Quick Reply: fast 102 sensor placement
