Suspension sounding like an antique... What to do?
I have a 2001 SS and the suspension is making an awful noise lately... Im guessing Im in need of new bushings all the way around but Im not sure. Cruising it is not too bad but when I go over bumps or get in/out of the car it make a creeking/squeeky sound. The sound comes from the front and rear of the car so im asuming its the bushings. Any help would be great just to get this fixed seeing how it is a very annoying problem. I HATE the sound and just want to see what I need to do to get it fixed! Thanks guys
New bushing would help IMO. You could also get some grease in the existing bushings. My TA used to do the same thing. Mine actually had worn groves in the bars by the time they were replaced.
LS1Tech Premium Sponsor
It's always a great idea to visually inspect your car when you change the oil. Shops will charge you an inspection fee, but you can jack it up and take a look pretty easily. See if your bushings aren't cracked. How many miles are on the shocks? Are all bolts tight? That sort of thing. Start there before buying anything. No need to spend money to solve a problem if it could be a simple fix.
Should you find anything broken or worn, that's when you ask yourself if you want to upgrade or replace with another stock part.
- Kevin
- Kevin
- Kevin
- Kevin
Ive got 75k on the clock on my 01 and Ive been thinking about changing the bushings for some time now. I heard you want to stay away from polyurethane bushings on F-bods.
Can I get a stock bushing kit from somewhere easily?
Has anyone changed them and notice a serious difference?
Poly isn't horrible as long as the natural movement of the suspension piece doesn't put it in a bind. Rear control arms and the panhard rod are a good example - they only articulate in a right angle from the bushings, so there's no lateral stress put on the bushings. Poly has a tendency to bind more than OEM/rubber with lateral stress or if not greased properly, so something like the front lower control arms, you're better off with either new OEM bushings, or going with a rod-end setup that won't bind.
Replacing old worn bushings with new ones can make a marked difference if the old bushings were dried out and rotting, especially control arm and sway bar bushings.
Changing the bushings alone can be a pain in the ***. I tried to press the stock bushings out of the factory upper a-arms and wound up bending both. For some things, like the panhard rod and rear control arms, when you look at the price of replacement bushings (either poly or OEMs) and the work to press the old ones out and the new ones in, it can be better to just buy a new aftermarket piece.
Yeah I know my rear sway need to be replaced. I'll prob just get new sway bars for handling purposes as well.
also, anybody have some instructions online anywhere for how the replace the rear lca?
It's a bit of a debated subject; some people prefer the harder poly bushings as they have less deflection than OEM rubber ones, some people prefer OEM because they're a bit quieter and less prone to bind in some situations, and other people like rod ends everywhere as by design they can't bind or deflect, but do give a rougher ride.
If you're simply drag racing the car most of the time then poly/poly are fine. But if you do mostly street you really do not want poly on the axle side of the rear control arms.
Technically, when the axle twists the arms also have to angle inward also, so for the best articulation you don't really want poly on the body side of the arms, but generally you're not throwing the axle at its absolute max twist (full compression on one side, full extension on the other) so poly on the body side is probably OK.
I'm not a fan of rod ends for a daily driver because of their inherent noise. For a street car like that I'd stick with rubber for the most comfort, or step up to a UMI Roto-joint or Founders swivel joint (or similar) if you want even better articulation without quite as much noise that rod ends will give you.
Also, technically the panhard does move in a lateral arc because the control arms force it to, but again it isn't a large amount and I suspect it would be like the body side of the LCAs - some side-to-side motion but there is a good chance that in most cases it isn't enough to warrant a more expensive bushing. I'd be tempted to stick with rubber on it however if I had the option.
No, not really. Their primary motion is up/down, yes, but that only happens if the entire axle moves up and down. If you angle the rear axle at all (which is what most bumps and turns will do), the axle twists under the car. You want at least the axle side of the bushings to be able to have twist capability if you drive the car on the street routinely.
With a stock panhard rod, I think the rod itself flexes enough that it doesn't put any side load on the bushings; an aftermarket PHR is going to put a lot more load on the bushings, but I agree that a hybrid setup is probably the best for most people - same with the rear LCAs.
A lot of bushing selection should be based on what the intent of the car is; a well-mannered daily or occasional cruiser would be perfectly fine with fresh OEM rubber bushings, while someone who wants a bit more performance but good manners could be better off with poly in some locations.
With a panhard rod setup, there is some side-to-side, which is one of the biggest inherent flaws with that type of suspension setup. When I ran poly/poly LCAs though, I never found them to bind a whole lot during normal driving - keeping them well-greased was probably a big part of that. I never got any noise with rod ends, aside from a bit of increased road vibration, until the ends needed replaced.
My car right now is just making 360rwhp but within a year itll be closer to 420rwhp. and then upwards of that down the road. I made the mistake of getting straight poly lca's.
I was going to sell them and get a hybrid poly/roto lca because it does squeek even when greased but should I just hold off considering later on the double poly would then benefit me with more power added?
So cars upward of 500rwhp poly is the way to go? or is it really best to go hybrid (roto/poly).
Poly/rod-end or poly/roto gives you a good combination of decreasing deflection while not being as harsh as rod/rod. With the poly on the body side, road noise and vibration will be a bit more noticeable, but not a huge amount. Rod/rod or roto/roto will give you the most benefit, since they're essentially impervious to bind and deflection by design, but they will transmit more road noise and need to be checked (rod ends have a finite life and roto-joints will need to be tightened up to account for wear). Brand-new OEM bushings will give the quietest and most compliant ride, but with no handing benefit at all.
Personally, every piece on my car barring front upper control arms are rod-ended. I went poly up the upper front because it's an up and down movement only, and the rod-end adjustable version was inordinately expensive for what is a pretty simple chunk of metal. It transmits a bit more road noise (I think, hard to tell over dumped duals) but there's no bind, no deflection, and it allows everything to be adjustable (there are poly/poly and roto/poly adjustables also).
