help with some issues with my car
Old 09-14-2012, 11:51 AM
spiro27's Avatar
Default help with some issues with my car
its a 01 trans am 6 spd. what i have done
eps 226 234 cam
tfs 215 heads
arh long tube headders 1/78
catted arh y pipe
have the 42lb injectors not on yet
ls2 t chain
hi vol oil pump
3 inch slp cat back
racetronix fuel pump and harness
42lb injectors.
what spark plugs should i be using in this setup?
should i be using tr6 with the cooler heat range. what the part nuber?
im gon re check my compression what should i get with a head and cam motor. 120 160. i dont know ?
thanks for help im trying to figure out the low power on this car over the winter.
Old 09-15-2012, 09:40 AM
spiro27's Avatar
i gess i would just use tr6 they ar e one heat range cooler.
does a cam effect what the engine compression reading should be. can i go by the spec in
the service manual or does the cam effect that.
Old 09-15-2012, 10:07 PM
spiro27's Avatar
anyone have any idea
Quick Reply: help with some issues with my car
