Picked up an 02 WS6 M6 47k
It's nbm with ebony interior and has the usual door panel cracks. All the other common problem areas are perfect. Perfect sail panel, no cracked dash pad, every light lense is un cracked, power antenna works, everything is in excellent condition. The only problems are the pass fender got hit and is cracked and believe it or not, there is a bullet hole through the driver door.
I plan on replacing the door and fender but can't find any door panels so I guess they will just have to stay cracked.
Only mods to the car is a borla cat back, jbl stealth sub woofer and amp, some kind of HID hi beams (white not blue) and chrome 08 corvette wheels. They're 18x9 and 19x9's I believe.
Paint is damn near perfect other than the damage which will be fixed. This car still has the stock upper air lid.
I appreciate any thoughts!
Story is some guys did a drive by and shot up his cars and house. He said chased them down and in the process the right corner got hit. After the guys got out of the car he said they realized they had the wrong address. Note to self when trying to kill someone be sure to double check the directions.
