stock tune, nitrous tune need help
Old 09-17-2012, 04:49 PM
busha61067's Avatar
Default stock tune, nitrous tune need help
ok, i have few questions, . do i need to go get tuned for nitrous or will colder plugs, timing retard, and possibly 110 octane suffice BTW i plan on running 150 shot. also i have no idea where to take the timing out in hp tuners like which tables and so forth. so if anyone has a tune with timing already takin out correctly or just a nitrous tune they can send me that is close to my cars mods that would be great. All one other thing, I have a frost tune does he advance timing any i need to know for nitrous purposes, Thanks in advance for all responses
mods - LT headers,exhaust,Volant intake,ls6 mani, 4;11 GEARS
Old 09-17-2012, 04:58 PM
redtan's Avatar
It really depends on whether it's a dry or wet shot.
A wet tune is usually just timing unless you're running a dry shot in which case a tune also richens the AFR.
Old 09-17-2012, 05:11 PM
busha61067's Avatar
its a wet shot
Old 09-17-2012, 05:12 PM
busha61067's Avatar
i didnt know if it was worth it to get tuned
Old 09-17-2012, 05:59 PM
wildcamaro's Avatar
Since wet system you are adding fuel so all you need to do is what you listed colder plugs and pulling timing which I believe is 1 to 1.5 degree every 50 shot...Are you using msd 6ls?
I think that 110 my mess you up unless you tune the PCM for the higher octane, wouldn't be gaining if no accommodating tuning for that high a grade of race fuel..
Old 09-17-2012, 10:57 PM
busha61067's Avatar
no stock ignition,can you get by with reading plugs from first 4 cylinders 2 on each side for tuning
Old 09-18-2012, 06:22 AM
MUSTANGBRKR02's Avatar
Why are you wanting to run 110. That fuel is leaded.
Old 09-18-2012, 06:54 AM
rmata's Avatar
Stick with pump gas for that setup. You'll be fine. You would pull timing from your high octane main spark table or you could use a timing tuner or iat tricker to do it. And if you were only going to pull 4 plugs I would do the back 4 instead of the front. Those are the cylinders that get more air (leaner) so better to tune off of those.
Old 09-18-2012, 10:57 AM
busha61067's Avatar
alot of people say it safer to run 110 with nitrous. also do i take say X amount of timing out of all tableso r just like everytable from 2k- 6k, i only rev to about 6so... and does frost add timing on hus mail order tunes.. thanks for all responses
Old 09-18-2012, 10:59 AM
busha61067's Avatar
sorry for poor grammar lol, i hate to get grammar slammed by someone ha, im just in a hurry
Old 09-19-2012, 08:30 AM
rmata's Avatar
I would do like 3000 and up rpms, from about .64 to the bottom of the high octane table. Log spark and do a pull to make sure it's within that region. I'd pull at least 6 degrees for starters. IDK whether frost adds spark to all of his tunes or not. Something you'd have to ask him yourself.
Old 09-19-2012, 09:20 AM
Or you could compare the stock table to yours and confirm what you have.
Old 09-21-2012, 09:09 AM
busha61067's Avatar
I compare my tune to stock,apparently i actually have timing taken out in some pkaces and timing added in others, so should i just go through were timing s more than stocke a take it out til its 3 degrees less than stock pland on running a 100 shot
Quick Reply: stock tune, nitrous tune need help
